Device to set a 3way valve for outside based on temperature reading with outside temp sensors
Does anyone know a smart device that can operate a 3 way valve with push and pull lever for outside that can be used on the Homey Pro system.
I would like if an outside temperature sensor (also not found a good working one under Homey Pro) measures above a certain temperature arround a plastic swimmingbath pipe that the valve system is set to an other side and back if below a certain temperature.
Is there anything on the market for that, preferably that can be bought in The Netherlands?
I use the SwitchBot Outdoor temperature and humidity sensor with a SwitchBot Hub Mini. They work great with Homey.
But then you need an extra hub between it, is that correct? And if so, must the hub be registered on the Cloud or cancel it run without and still Homey Pro can make use of it?
If I go the new device and search on SwitchBot, I don’t see the Temperature and humidity sensor for outside on my Homey Pro, is that correct and can it not be added this way? (I found the site of SwitchBot and the outside sensor)l, that is why I want to be sure Homey Pro can use it).
Ps. Anyone on the other part of my post?
Homey’s BLE range is quite bad, so a SwitchBot hub is highly recommended and is also what I use. It uses a cloud connection, which makes it very stable and reliable.
Just add it as the “Temperature and humidity sensor (Hub)” in the Homey Switchbot app, that also connects the outdoor version
