I copied it, just as it is now (device is in anti frost mode, 7 ° C)
| Code | Type | Values |
| temp_set | Integer | { “unit”: “℃”, “min”: 50, “max”: 400, “scale”: 1, “step”: 5 } |
| temp_set_f | Integer | { “unit”: “℉”, “min”: 410, “max”: 1040, “scale”: 1, “step”: 10 } |
| factory_reset | Boolean | “{true,false}” |
Above is the instruction set. The status set has this line added:
| temp_current | Integer | { “unit”: “℃”, “min”: 0, “max”: 450, “scale”: 1, “step”: 5} |
