Despite Ikea light sensor, light always turns on
Who can help me with the following, I have made an AF where the lighting should go on as soon as the light brightness (Lux) is lower than value X and movement is detected.
However, the light always goes on when movement is detected.
Does anyone have an idea what is going wrong?
The value you entered for “Helderheid” is: minus 20 (-20), you probably need a positive value
Unfortunately, even with a + value the light always goes on.
I have tried multiple values. both plus and minus
And what’s the value of #Helderheid at those times?
You are using the “NOT” exit of the Logic card, try to use the Upper exit (“TRUE”)
At the moment it’s 9 lux
Do I understand correctly that you mean that I used the bottom exit in Logic but that I should use the top one?
I have tried that now but when I test the Flow the flow does not continue from Logic to Switch the lights on
Still using -20, make it 20
Why are we looking at “0.2” now?
no matter what number i enter i get the message number is false.
tried 0.2.
tried 20 etc
Can you add a card after “De tijd is tussen …” and send a push notification to yourself containing the #Helderheid tag?
Are you sure you have the right “Helderheid” tag, I mean, the tag from the right device?
The problem is solved.
Exactly as you just stated.
Tag Helderheid was incorrect.
Thanks everyone for helping
