So i have Zigbee wall switches and also Zigbee Bulbs.
Is there any way in a flow that i can set up so the bulbs are not accidentally put into pairing mode if the switches are clicked to quickly?
Any ideas thoughts or comments. All appreciated
Smart bulbs aren’t meant to be power-switched, it’ll wreak havoc on your Zigbee network if you do.
Check if your switches don’t have a “detached” mode, where toggling the button doesn’t also toggle the internal relay. Then you can use the switch as an actor and use flows to toggle the lights based on the switch actions.
Agree with @robertklep here, as soon as you remove the power from the zigbee bulbs, they are unreachable for homey.
AND
when they are unreachable flows will not have any effect either. So looking for a flow will not bring the sooution…
