found it, one above 35mb and the rest underneath that number.
I have tested two homeyâs2019 and both same issue. somethimes days no dropping off and sometimes 3 or 4 times in a day.
OK, then the only thing I can think of, both of your Homeyâs are Homey4d models (look here for HomeyModelId), or thereâs a thing with your wifi system Homey can´t handle very well.
What kind of wifi system do you have? A mesh with several Access Points?
indeed Homey4D, is that an issue?
i have Unifi, i have been using Homey for long time and no issues, issue started since a month ago, nothing is change on my wifi or network. indeed mesh with several AP but i have setup homey to connect to one AP.
Can you recall if the problem started after a specific firmware update on Homey?
Yesterday I moved my homey very very close to my unifi AP, till now 18 hours later no dropping off. If stays like that, I will keep it at the current place.
Thanks Peter for thoughts, I have done that and I done also that Homey only connected to this specific AP. It seems there is something in my leaving room blocking the signal.
I have one AP in my leaving room and I moved Homey next to it and still it had issues. Right now itâs in the hall and no issues till now. 22 hours connected.
Bedankt.
Good to hear!
