Dashboard camera snapshot automatic refresh
Is there a way to automatically refresh the snapshots in the dashboards?
Or can i make a flow which sends the new snapshot to the dashboard?
Thanks in advance!
I just created a flow with refresh every 5 minutes. Or with dashboard controller when dashboard gets active get a snapshot. It looks like its caching the snashot so mostly on first load it shows a snapshot from 3 days ago.
Hello Elmar,
I would like it to refresh when the dashboard gets active. What is dashboard controller? Is this a app which i can download? Where can i find it. Sounds like a good solution!
This works with fully kiosk (android only)
The you can make a flow when dashboard get’s active fetch a snapshot (with a delay, to give the dashboard some time to load)
How do you get the Dashboard to “fetch a snapshot”? I do not seem to find this action? Sorry if its obvious, this is my first post =)
Sorry that part is from your camera app. I use ONVIF app
Well, the pictures from the camera on my dashboard does not get updated, only way to press the “Update” symbol in bottom right corner, then it updates. Of course most useful would be if you could start a live stream from the camera when pressed.
Auch bei mir werden die Kamerabilder, trotz Flow mit Auslösern von Schnappschüssen, auf dem Dashboard nicht aktualisiert. Ich bitte die Entwickler um eine Lösung!
VlG. Hagen
Ok thanks i have an ipad. So this will not work.
Hi
Do we know if there is a possibility to be able to refresh the thumbnails on a ipad?
