Thanks! I have now (with the help of ChatGPT) put this together. I still isn’t finished, but it’s promising!
// ----- Configuration -----
// Fill in your Sirv API Client ID and Client Secret
const clientId = 'your_client_id';
const clientSecret = 'your_client_secret';
// Replace 'your_account' with your Sirv account name
const accountName = 'your_account';
// The URL of the image you want to fetch and upload
const imageUrl = args[0] || 'https://example.com/image.jpg'; // Adjust this to your own image
// The location where you want to save the image on Sirv
const destinationPath = '/uploads/my_image.jpg'; // Adjust this as needed
// Specifications for cropping
const cropWidth = 600; // Width for the crop (in pixels)
const cropHeight = 600; // Height for the crop (in pixels)
const cropX = 0; // X position for the crop (in pixels)
const cropY = 0; // Y position for the crop (in pixels)
// ----- Functions -----
// Function to retrieve the access token
async function getAccessToken() {
const authUrl = 'https://api.sirv.com/v2/token';
const response = await fetch(authUrl, {
method: 'POST',
headers: {
'Content-Type': 'application/json'
body: JSON.stringify({
clientId: clientId,
clientSecret: clientSecret
if (!response.ok) {
throw new Error('Error retrieving access token: ' + response.statusText);
const data = await response.json();
return data.token; // This is the Bearer Token
// Function to download an image and convert it to ArrayBuffer (binary data)
async function downloadImageAsArrayBuffer(imageUrl) {
const response = await fetch(imageUrl);
if (!response.ok) {
throw new Error('Error fetching the image: ' + response.statusText);
const arrayBuffer = await response.arrayBuffer();
return arrayBuffer; // This is the image as an arraybuffer (binary data)
// Function to upload the image to Sirv as a binary file
async function uploadImage(accessToken, imageBuffer, destinationPath) {
const uploadUrl = `https://api.sirv.com/v2/files/upload?filename=${encodeURIComponent(destinationPath)}`;
const response = await fetch(uploadUrl, {
method: 'POST',
headers: {
'Authorization': `Bearer ${accessToken}`,
'Content-Type': 'application/octet-stream' // Binary content type
body: imageBuffer // Send the image as binary data
if (!response.ok) {
throw new Error('Error uploading the image: ' + response.statusText);
console.log('Image successfully uploaded to Sirv.');
// Function to generate the cropped image URL using URL parameters
function getCroppedImageUrl(destinationPath, cropWidth, cropHeight, cropX, cropY) {
const croppedImageUrl = `https://${accountName}.sirv.com${destinationPath}?cw=${cropWidth}&ch=${cropHeight}&cx=${cropX}&cy=${cropY}`;
return croppedImageUrl;
// ----- Main Script -----
(async () => {
try {
// Step 1: Retrieve the access token
const accessToken = await getAccessToken();
console.log('Access token retrieved:', accessToken);
// Step 2: Download the image and convert it to ArrayBuffer (binary data)
const imageBuffer = await downloadImageAsArrayBuffer(imageUrl);
console.log('Image successfully downloaded as binary data.');
// Step 3: Upload the binary image to Sirv
await uploadImage(accessToken, imageBuffer, destinationPath);
// Step 4: Generate the cropped image URL using URL parameters
const croppedImageUrl = getCroppedImageUrl(destinationPath, cropWidth, cropHeight, cropX, cropY);
console.log('Cropped image URL:', croppedImageUrl);
// Step 5: Update the Homey logical variable with the new value
const vars = await Homey.logic.getVariables();
const myVar = _.find(vars, (o) => o.name === "GecropteAfbeeldingURL"); // Adjust the name if necessary
if (myVar) {
await Homey.logic.updateVariable({id: myVar.id, variable: {value: croppedImageUrl}});
console.log('The cropped image URL has been saved to the variable "GecropteAfbeeldingURL".');
} else {
console.error('Variable "GecropteAfbeeldingURL" not found.');
} catch (error) {
console.error('An error occurred:', error.message);
FYI - If you replace your language specific link with the non-specific one, then users will be redirected to their local language version in the Homey App Store when clicking the link: Image Crop | Homey.
