Are there any other devices, that can be connected to homey, other than the Tahoma switch or the connectivity kit to control a Somfy IO roller shutter motor. On one hand the connectivity kit only works with the cloud (which I do not like) and on the other hand I thinks it’s a bit of overkill to use the Tahoma switch to control just one roller shutter.
Not that I know of, otherwise Homey wouldn’t need a Conn. kit or Tahoma box. The 3rd possible hub is Connexoon, but that’s (being) deprecated afaik.
You can check the info @ Somfy Tahoma app topic, the link can be found on the app page at homey.app store.
