KlikAanKlikUit Roller Shutter
Hi All
I’m a newbie to Homey, so I hope You’ll forgive me if my questions are stupid.
I’m curious to know if it is possible to combine the :
KlikAanKlikUit Roller Shutter - https://klikaanklikuit.nl/product/schakelaar-voor-zonwering/
and any universal tubular motor like this - 25mm Tubular Motor 110V 220V Automatic Electric Roller Blinds Shutter Motor for 38mm Tube Tuya Smart Home Wifi Curtain Switch|Automatic Curtain Control System| - AliExpress
and make this work with Homey, when I install the KlikAanKlikUit app ?
Hope this makes sense :0)
Thanks for Your help and advice.
/Frank
In Homey it is ony relevant if the devices can be connected to Homey via one or more Apps, so, search if there is an App for the KaKu-switch and search for a (tuya) App for the motor. If both are available, then they can be ‘combined’.
I use the KaKu ASUN-650 with Homey. There is a KlikAanKlikUit app for Homey. You can use it manually or make flows.
And the Not for this Community relevant part of the question you ask:
I Don’t see how, and if you ask that you probably need an electrician!
