Hello - hope you’re all well.
I have 2x Yale locks in my house a Conexis L1 and the YD-01-CON. The Conexis connects no problem at all and works well within Homey Pro but the YD-01-CON just does not want to connect at all. Both have the new yellow Yale Access Modules installed and the Yale Digital Lock app is loaded onto my Homey Pro.
Firstly the instructions through the Add Device are incorrect - it states that the connection process is Master Pin No, #, 4#, 3#. The Yale instruction booklet states to connect to a Smart Assistant that the process is Master Pin No, #, 4#, 1#. Neither work.
Has anyone got this added to Homey Pro and if so how did you do it?
Cheers, Al
