I have purchased two FSG-222 (Relay Switches) so I can install them on my legacy alarm system. I have a system called BiBus Classic S system. (Not sure if you have heard about it).
I would like to connect the switch relays in the following manner:
• Port 1: Arm and Disarm (all sensors)
• Port 2: Arm and Disarm (Perimeter – some sensors)
• Port 3: Trigger alarm
So on port 1 and 2, I would need to send an impulse to arm or to disarm and on port 3 I need to open or close the circuit to trigger the alarm. Note that all 3 ports have been configured on the alarm system to arm/disarm (ports 1 and 2) and trigger alarm (port 3). So on the alarm system side things are ready.
Below you can see the wiring model:
Given the above, can you please let.me know how to connect wire the FGS222? What should I connect on L, N, IN, Q1 and Q2. Since I have three ports one will remain idle.
Thank you,
Emmanuel
