Does anyone know how I can control the Intex Spa with Homey? It is possible with HomeAssistant.
Any update somebody?
If anyone has created a solution, really looking forward to combine heating the Spa mainly when there is enough energie production by my solar pannels.
Any update on this topic? I’m new to Homey and don’t believe my spa would be the only one cannot be controlled with Homey.
I really want to know the answer to this too! I have the octagon 6 persons version with wifi.
You can connect through an app on the phone to control the jacuzzi. There must be an option to make Homey to talk with it right?
Did you search the app store?
Ofcourse but you need a diy hardware tool for that one. Should be a way around it.
You can install Home Assistant which has an Intex integration and then use the Home Assistant app for Homey.
I am a newbie to MQTT, I have searched and read about different topics to connect my Intex Spa to homey, by means of the app, MTTQ client and broker. I know I have set up the client right to connect to the broker, however I can’t figure out how to use the app Intex Spa, connecting to my Spa and showing up in the dashboard of homey. Can somebody try to explain how to setup this app. It is for me it is really hocus pocus, and I know I am not the only one, so any help is appreciated. Thank you all.
I got the same problem. MQTT Cleint and Broker are setup but can’t paire the Intex spa
"Ciao! Riscontro un problema permanente di connessione con l’app Intex PureSpa (v1.1.1) su Homey Pro.
Problema: Inserendo l’indirizzo IP locale della spa nelle impostazioni di configurazione dell’app, la connessione fallisce sistematicamente restituendo l’errore ‘Fallito’.
Test e reset già eseguiti:
Ho già effettuato un power cycle completo (tolto e ridato corrente sia alla spa che ad Homey Pro).
Ho riavviato e riaperto le app (sia Intex che Homey).
Ho verificato che l’IP [inserisci IP] sia corretto e che la spa funzioni regolarmente dall’app ufficiale Intex sulla stessa rete Wi-Fi.
Nonostante tutti questi tentativi il problema persiste. Inviato report diagnostico contestuale per l’analisi dei log."
92de8e0c-0e6d-4590-9f8c-b7c8761f6f5b
