Good morning,
Do flows depend on the cloud?
That is to say, if Homey is cut off from the internet, will a flow continue to work?
Assuming you mean for a Homey Pro: unless the flow depends on devices or apps that require internet access, the flow will work without an internet connection.
hello, indeed a pro 2023. Even if I launch the flow manually?
That’s a tricky question, because launching a flow manually means you have to run the app, and the apps don’t have a great track record when it comes to dealing with a missing internet connection (often saying that Homey is offline).
