Cloning 433mhz devices - does it work?
Since 12.5.0 it is possible to clone a 433 mhz device.
So you clone all buttons of the remote device, then add a device.
From then you can add a ‘send command’ for that device to a flow.
I have now tried it for two devices but, for some reason, it does not work.
What can I do to troubleshoot the issue? Could it be that the 433mhz device is not strong enough in the Homey?
Did you read the common (user) problems that you can click during the start of the pairing process?
Yes I did.
This one, right?
And I understood the garage door opening remote probably using a rolling code.
But the Novy V2 Hood should work (Yes I know there is a dedicated app, but it is not supported for Homey 23) but it doesn’t.
A TV and amplifier with 433MHz remotes. Interesting! Mostly IR & Bluetooth is used for those categories.
I have tried cloning a generic LED strip remote and although all buttons can be cloned and the device is added, when I try to use is I get an EINVAL (2:write) error on all buttons.
No idea what’s going wrong here.
Athom’s QA process has, this is a firmware bug.
I have the same error.
Gemini AI says about this error:
The “Einval” error in Homey with 433 MHz devices usually means “Invalid Argument” or an invalid value. This indicates that Homey tried to send a command or interpret a signal that wasn’t correct, or there’s an issue with the 433 MHz module itself.
For me it doesn’t work also.
I tried with 3 different devices. No rolling codes.
I was hoping to use this new function. For now I am using SONOFF RF Bridge (with HA paired to Homey) and it works perfect
Doesnt work for me either.
No error messages, but using phone camera I see that iR tranmitter is not lighting up when I use cloned IR commands.
Testing with the built in infrared devices I see the IR transmitter light up in phone camera ok.
Must be a bug.
So is the new feature actually capable of cloning IR remotes? Because everywhere I read it states it’s for 433 Mhz remotes, which obviously is a completely different thing.
I tried cloning my Novoferm 522 garage door remote. Cloning seems successful, but it does not work when testing in the homey app.
How far is your Homey from the garage door receiver? Homey has historically had quite a limited 433Mhz range.
8 meters with no walls, I got the Homey Pro in the back of my garage.
Oh never mind, it looks like that remote uses rolling codes, which means it cannot be cloned by Homey.
No rolling codes but not working for me also. And the device is next to homey. Homey learn the mhz but when i touch the button its just doesnt work at all. But as i see almost everyone got the same problem. :smirking_face:
Guys, it’s all explained
Promotion email:
The page you see when you followed the link:
Works for a switch from nexa but only from the item created for 2 buttons wit on and off.
Trying to use any of the commands in a flow just does not work. Any one who knows how to use a 2 button switch each button handles one, on and off for each button?
Hi Peter,
Ive read the HowTo’s but do not think this is the issue here.
If you would use a remote with a rolling code, Homey would try to send the programmed signal, but it just wouldn’t do anything on the device you’re trying to control.
Since 433 is a one-way communication, it would not reply an error message, hence Homey cannot know there is a problem on the device side.
Since the app returns an Einvall error, the only logic explanation would be the error is in the app or firmware of homey (like our resident homey-guru @robertklep :wink: ) already stated.
I will keep trying when newer firmware and app versions if the problem is solved for me and report back.
:face_with_peeking_eye:
Restored…
