Bonjour
Je constate que mon Homey pro a une charge processeur qui arrive a presque 400% toute les 30 minutes.
quelle est la solution pour éviter ces charges trop importantes qui peuvent générer des aléas dans mes flows
Bien cordialement
C.BARRES
If you could please keep the conversation in English as much as possible, then more people will be able to participate and help you. If you would rather not or can’t communicate in English then please check out Non-English boards/categories:
therefore moved
