I would like to change the colour of my Homey Pro 2023 LED ring to use them in my flows.
I want to set colours for a x amount of time, Is there a way to do this? I saw an app, but its only compatible with the older Homey device.
Thanks!
Thanks!
Something like this?
If: anything, for example “This flow has started”
Then: Animate Solid color for X seconds
Exactly! Is this possible on a 2023 Pro?
I don’t know, I only have a Pro 2019
Well, the duration can be used with the two flow cards “pulse” and “loading”.
I added the information in my first post.
Thank you, found it!
Unfortunately, the duration can only be up to 10 seconds, which is strange.
