Can't make this Homey Advanced Flow repeating
Any clue how I can make this flow repeat like I entered?
I’m trying to keep the lamps of the “Entree” on as long as at least one of those zones are active, if not then it can go out.
You are trying to connect to a trigger (When) condition, that is not possible. You could connect the ANY to the Entree ’Is active’ condition.
(post deleted by author)
Nope, you can’t create loops this way.
You have to create a trigger this flow card but I think you should avoid that also as it isn’t necessary if you have a wel thought set of triggers.
I think you can make your flow much simpler: Every time a zone becomes inactive check whether all the other zones are inactive.
