Can´t get Fyrtur to pair with Homey and remote at the time
Hi, I recently bought Fyrtur, and it works fine with the remote control OR Homey, but not both at the same time.
When I pair Fyrtur with Homey, the remote control stops working. When I pair Fyrtur with the remote, Homey stops working.
Should this work?
No clue what you mean… please read this for a moment, thanks:
No, this will not work, this is normal behaviour, using zigbee, there is always only one host that can control the device.
I thought it was very clear
You have to pair Fyrtur and the remote control with Homey. Then you have to build some flows.
If…
— Down button was pressed
Then…
— Set position on 0 %
And so on…
You can also try this. Don’t know if it works with Fytur and the Up/Down remote.
Thanks, I will try this
