Can somfy Zigbee motors be used with the current somfy app(s)?
But that is for a different component called “zigbee:SomfyConfigurationToolComponent” and the app can’t cope with multiple components like that.
In that case we can just add a new device in the app right? It also seems wrong to add a zigbee device, with the IO device from the list of devices. If that is possible, I will try to make a pull request. Please let me know
@Adrian_Rockall can we then add a new device/component to the library? I really would like to get a notification when the battery is almost empty so I know to charge it.
@Adrian_Rockall I have the Tahoma switch and the zigbee sonnese 2 40 motors in Jalozie.
how i get them in Homey?
I’m already try to get them in.
I have made token and tahoma in dev. mode.
I get complete lost in it.
Can you install the test version of the app, then go to the app settings page and select the Driver Support tab.
You should see and devices that are supported in the beige panel and which driver to select in the Add devices process.
If you scroll to the bottom of the list, you will see any devices that are not supported. If you click on that list it will send the information I need to add support.
Thanks, that is very helpfull. Now i have them in Homey. With the test version.
tomorrow furter with testing and made flows for it.
Thanks :smiley:
ff8cff5a-5c65-43ac-afdc-dd4183d1a912
Edit: I tried every one except the roller shutter (IO) — came back a few hours later and finally saw that comment
TaHoma, 9 Sonesse 28 Zigbee motors, 6 remotes, and a hue smart switch they had me buy when I had to call up about devices dropping
haven’t been able to figure out how to see them
there may be some garbage in here, I’ve had to re-pair some motors, and one of them doesn’t report battery in TaHoma app; wouldn’t mind starting from scratch if I have to if it looks odd
