Dijker
April 25, 2025, 6:51pm
1
Adding IR or RF 433Mhz devices on a Homey Pro tells you you require a Homey Bridge
This BUG is verified running specific Homey Mobile App versions on Android and iOS.
Verified on some versions on Android,
Workaround is to use the Homey WebApp on a Desktop or sometimes to leave the Beta App (on Android and Remove / Re-install the normal App)
Note: I just see the bug is also in the Latest Stable version 9.2.1
Homey Mobile App Changelog | Homey
Dijker
2
Bug is reproduced in in following versions:
9.2.1.1727 (Beta)
9.2.1.1735 (Beta)
It works as expected (No Bug) in the regular release (Tested on Android):
So probably remove the Beta
(And having a Bridge as Satellite on a Homey Pro Early 2023 you don’t have this issue. )
I have a homey pro 2023 and when i want to use any app to connect my 433mhz remote i get a message to buy a homey bridge! Is this new?
Dijker
April 25, 2025, 3:38pm
4
Looks like bug Introducing a option for Homey Pro mini.
Ok! When i do it on a pc, this function is available like normal!
My next question is how i can connect my 433mhz remote to homey! I have tried it with the brel app remote but when i press a button nothing happens! Is there something i do wrong or is not every remote working with this app?
Dijker
April 25, 2025, 4:58pm
6
You need an app specific for your brand remote.
Of course not every remote works with the Brel app. We just discovered it works with some, other than Brel, remotes.
Which remotes? No one knows. It is trial & error, and a bit of luck.
Here’s another one, Geurt. I thought he might have started a Homey Cloud instance by accident, but he says he’s connected to a Pro:
Ik ben bij een Belgische provider Telenet en heb een Modem type CH8568LG
In de modem heb ik geen instelling gevonden om de ipv6 adr. uit te zetten.
Ook eens gegoogeld en lees ik in forum dat dit niet mogelijk is.
OP de test-ipv6 is mijn score 10/10
Is gebeurd.
het zigbee netwerk is nu in orde na het terug koppel van verschillen end-devices
MAAR somfy RTS werkt niet ? (433Mhz)
Ander 433Mhz apparaten wel.
Somfy app. herstart - geen verbetering
Somfy verbinding repareren is er niet dus pr…
Ok thanks for the info! I will have a look if there is another way!
I have the same problem with the Pro 2023 version.
This on 2 different iPhones and an iPad.
Homey app is version v9.2.1.1734
Pairing 433Mhz does work via the web version of Homey on a PC
Note that the Homey app for apple has recently been updated.
I suspect that is the problem.
Title improvement suggestion: Can you replace “RF” by 433 MHz please? Or just add 433 MHz?
I think not many users will get 433 MHz is also referred to as RF, and won’t find this bug topic.
Thx!
The problem is already explained in the 1st topic.
I have several Cleverio and Nexa devices that work perfectly with Homey Pro 2023. Now, when I try to add more, I get an error message saying I need to buy a Homey Bridge to add more 433 MHz devices. This happens with both Nexa and Cleverio. Does anyone have an idea what might be wrong? Homey and all apps updated to latest version.
Use the web app please, or install the stable mobile app version.
There seems to be a bug in the beta / testflight app versions.
But i don’t have a beta or testflight version and i also have this problem still! So i think its a bug in some of the latest updates
Dijker
April 26, 2025, 3:19pm
16
But what version do you have and on what platform. If you want help please provide information
[Tip] Problems with Homey?
Homey pro version 12.4.2
Iphone version 9.2.1.1734
I have the same problem as Peter_Heemskerk and runs the exakt same versions of the app and Homey Pro. This is a recent issue for me as well.
Dijker
April 26, 2025, 7:59pm
19
Dijker:
Updated OP, as Yesterday I verified that leaving the Beta worked for me to go to a v9.2.0. but the 9.2.1 is already pushed with Bug to stable.
And it also affects adding IR devices.
Only Workaround left is
is a bug in Homey Pro FW 12.4.2
See Homey Pro (Early 2023) and Homey Pro mini Changelog | Homey
Resolved in Firmware v12.4.3
RF
Fixes an issue that caused a “Homey Bridge required” error to be displayed when adding RF devices.
IR
Fixes an issue that caused a “Homey Bridge required” error to be displayed when adding IR devices.
The problem was iddly solved by installing v12.4.3 on the Homey
App.version remains v9.2.1.1734
