Bridge / Flow Question
Just received my Bridge today.
Have setup Hue and imported all the downstairs lights, can’t get the upstairs as I can only import on hue hub.
I can see all the lights correctly assigned to each room.
How do I create a button to turn on all lights in a room or turn them off, it appears that a flow requires an event, is there a way to create a button in Homey to trigger off?
You van use this flow is started as trigger and make it a favorite flow or even create a widget on your homescreen
edit: it helps for a better WAF if you keep the name and action consistent :ok_hand:
Or look here
Awesome thanks!!
The Virtual Devices won’t install on a Bridge :frowning:
Just read the full article :grin: ClickOnClickOff is the trick
