I read a lot about the Homey bridge in satelitte modus but on the website there are some strange things.
As I know extending BLUETOOTH is not working in satellite modus. But screenshot below says something else for my idea.
I just want to know for sure. If I buy a bridge and install this in my poolhouse, would I be able to connect Homey with some bluetooth devices overthere.
For example I bought a Yinmik pool monitoring device. For Ph, Chloor, …
The device has an app on Homey (thanks to T. Hill, see topic here YINMIK Pool Monitor )
But my Homey Pro is too far away to get the bluetooth signal and info from the device.
So I want to add bridge closer and have good connection.
But you read a lot on this range issue here. But never a solution…
So for once… Is there somebody knowing if that coudl work or not ?
Bluetooth isn’t supported (yet?) on the bridge when in satellite mode, the bluetooth reported on the page you show is just from the main device.
And the app wil be a community app, so not supported with the bridge when you would use it with a Homey in the cloud.
If you want to stay in the Homey eco system, you’ll have to buy another (/older) Homey Pro and then add the device with HomeyLink (or Homesh) to your main Homey Pro.
Or ask Athom when (/if) they will support bluetooth for the bridge in satellite mode.
Another Homey Pro is expensive I think. Also I already bought antena for Ruuvi because of lossing the bluetooth signals from those temperature sensors. 200€…
But is there really no other way to extend bluetooth signals ? Or signal boosters ?
I will try Athom but I see a lot of people trying and seems Athom don’t listen
Yes, not being able to extend Homey Pro’s BLE range is very limiting given a lot of battery powered smart devices utilise BLE for its obvious energy efficiency.
And it is not only the range. Bluetooth simply freezes and stops working, requiring reboot. This happens in irregular intervals every few days. Bluetooth in Homey Pro simply sucks.
Homey knows that we know that they know, but the problem persists. I’ve learned to live with it, but from the pov of device manufacturer and app developer I would think that this type of problem is even worse. At least I don’t even consider buying more BLE devices until problem is solved.
