Brel, bi-directioneel
I have 2024 sun blinds and I have Brel bi-direction motors I guess. I have a HUB-03. Also a remote DD2702. However I tried like 3-4 apps and so but no luck. I get see any devices popping up in my pro23. Any advice/update by now? (I saw all messages here)
I also tried the MontionBlinds app, and added the secret code/key I could get via the Brel Home app on my Android phone, but still I cant find/pair any screens… :frowning:
ok, but how do I install this on my Homeypro23 :open_mouth: I am new to this github stuff…
I do not know if it works for your specific device since it is newer type of hub. Here you can find information on how to install an app via Homey CLI: [HOW TO] CLI install method and Getting Started | Homey Apps SDK .
It works.
I had to also enter the 192.168.1.19 internal IP to the Motionblinds app settings!
Nice that it works, you might want to consider to make it a fixed IP in your router so it doesn’t break when the router assigns new IP’s. Happend to me too.
I have the Brel DD1554 hub that is connected to my Homey Pro 2023. First with the Brel app, but my dual roller blinds don’t open in the correct way when i want to open them at 50% for example.
At 50% they lower a bit to much and at 49% they lower a bit to little. Now i tried the MotionBlinds app and connecting with the hub was no problem, but still i can’t get the blinds to lower to the correct position.
I asked Brel if i could be possible to set the percentage with 1 digit after the decimal point, but they don’t respond to email and on the phone they told me they don’t respond to customers.
Is there any other way i can set my curtains to 49,5% for example?
I just re-added a brel solar shutter.
But i notice its not showing the battery status anymore. It does in the brel app. And my other existing shutters do still have a battery status. Anyone familiar with this?
I think you can just calibrate it in the all again with top and bottom and it should be okay
The top and bottom of my dual roller blinds are not the problem. I’ve set these to open and close at the right position.
It is in the position they are during the day. Then they open at approximately half way, but in the Homey app and the Brel app 50% is a little too much and 49% is a bit too short, so the separate ‘lanes’ overlap instead of completely open.
The right position should be like 49,5% so they don’t overlap anymore.
By the way, i still got the battery status in the Homey app.
