Hi @gslender
Trying my luck again…
As previously described, I was able to set my blinds to a specific position (percentage) via flow cards, but the control slider itself never worked (image in my previous post).
I hadn’t used the position cards in my flows for a long time, but when I tried to use them today, they no longer work. This must have been caused by the last update (yes, I know it was over seven months ago), because it definitely worked before. So now the control slider is broken (as it was before) and the percentage flow cards don’t work.
My blinds do support percentage based positioning as it works in the Bond Android app (via slider similar to Homey controls), but on the Homey Developer page I only see:
windowcoverings_state, which showsup,down, oridlewindowcoverings_set, which is always1, regardless of how open or closed the blind is
As said, I’m 100% sure I was able to control the position (percentage) before, and the blinds clearly support it (works in the Bond Android app).
I would be really grateful if you could look into this.
Thank you.
Cheers,
Alex
