Bond bridge intigration
It connects via the local bridge.
Thank you so much for the integration, I m having issues with my fans, the speed is hard to control with what looks like a light dimmer, my bond has multiple speed levels 1-6
The fan does have a light which is in bond but is not controllable in this app, the light is a simple on off, bond integration calls this toggle light.
Hi, I have fans with lights and am willing to do testing to get that working. I just got setup yesterday, but I cannot control the integrated lights for any of my fixtures. I have 3.
@gslender I have the latest version of the integration installed, 1.2.6. I have restarted the app and the whole Homey hub multiple times. No light control option shows for any of the 3 fixtures that I have, even though it shows a toggle light option in the Bond app. How do I get you diagnostic information? Do I need to run a special version of it?
The app supports bond fans with light option. Not sure why you’re not seeing them. Have you tried removing the devices and re-creating them.
In the device, the Advanced Settings has Bond Device Data and Bond Device Properties. I will need both to trouble shoot issues.
No, the current release you are running Version 1.2.6 is correct
@gslender Okay I have taken a couple days and tried to remove the devices a few times, including restarting the app and the restarting whole device before re-adding the fans.
Here is the diagnostic information for one fixture, all 3 are the same make and model:
Device Data
{“status”:“VALID_TOKEN”,“data”:{“name”:“Josh Fan”,“type”:“CF”,“location”:“2nd Bedroom”,“tech”:240,“actions”:[“DecreaseSpeed”,“IncreaseSpeed”,“SetSpeed”,“Stop”,“ToggleLight”,“TogglePower”,“TurnLightOff”,“TurnLightOn”,“TurnOff”,“TurnOn”],““:“6970d012”,”__“:“2fef68a0”,“commands”:{””:“32e5d161”},“state”:{““:“f7760177”},“properties”:{””:“b17cd87a”},“skeds”:{“_”:“00000000”},“id”:“06fb74b1a6585a76”}}
Device Properties
{“status”:“OKAY”,“data”:{“max_speed”:2,“trust_state”:false,“_”:“b17cd87a”,“__”:“b17cd87a”}}
Please let me know if you need anything else.
Are you 100% sure your Bond Bridge is running the latest firmware? The properties don’t contain the necessary ‘feature_light’ object which is why the fan is being setup without any light features.
It is not normal for the Bond Bridge to report TurnLightOn/TurnLightOff actions but not reflect the feature_light properties.
My bond bridge is running 4.7.7 according to the app, that is the latest version and thats what it has been running since I started importing the fans. Whats the next step? Are there more diagnostics that I can get you?
I’m unsure why Bond don’t consistently report device features like they report in their API.
Given this, I may need to detect the actions available, and add the feature for the device based on that instead - I guess that’s going to work, so leave it with me to update and adjust how the Homey app works.
Hi, where do I find the token I must enter?
  1. Open Bond mobile App
  2. Open your Bridge
  3. Open Advanced Settings
  4. Local Token is what you are after.
This is also mentioned on the Homey Bond App front page… so you must of missed it !?
Thanks, that fixed it :slight_smile:
Yes, sorry. I just skipped right past that :man_facepalming:
Hello, new to the forum. Can anyone confirm that the light functionality works in the app?
Hello, thanks again for the app. I am able to connect to the bridge and see all of the fans setup with the Bond Bridge. As a device in Homey, I am able to fully control the light, fan, fan speed, and even direction. All looks great! Then when I go to make a flow the only cards available for “then” are off and on, which only turns the fan light off and on. There is no functionality for the fan itself. Am I missing something? Thanks for your help!
I’m having trouble with my blinds and was hoping for some help.
The slider control that allows setting the open/close percentage doesn’t work properly. As shown in the attached GIF, no matter where I drag the slider, it always snaps back to the bottom. As a result, the blinds fully open or fully close (depending on their previous state) instead of stopping at the selected position.
The alternative control using the up/down/stop buttons works as expected. My flows also work correctly, I’m able to open or close the blinds to an exact percentage when it’s set within a flow.
This issue affects all seven of my blinds, two different manufacturers/brands.
Do you have any idea what might be causing this? Alternatively, is there a way to make the button controls the default view so I don’t have to swipe to access them every time I open the blind controls?
Thanks in advance!
shade_1
Hey, how do those keys, tokens work? What is the workflow, where do I need to insert them along with the IP address, please? I am a bit lost here
All Homey Apps have a Configure section if the App requires it. This app does. Its fairly straight forward and the Homey App page on the website explains where to get the token from. The rest is obvious. Provide more details of where you are stumped if you need more help than this.
@gslender
Could you please share some insight on my issue from two posts above?
Thanks!
