It sounds interesting. I installed it but I don’t understand how to configure it.
I presume it currently only supports one sensor and one light for the whole house?
What do the ID numbers that can be entered refer to?
Currently I have a sensor in the hall for the hall light, a sensor in the cloakroom for the cloakroom light and a sensor in the bathroom for the bathroom light. Is it possible to configure all these?
So example for the hall light,
lightname: Hallway
motionsensor name should be something like :
PIRDN5Hallway
PIR = Prefix
D = dimmer identifier
N = night identifier
5 = time
Hallway = lampname
The settings allows to change the location of certain identifiers and or disable them
There is a fix waiting for approval in the store to fix the location of the identifier, with version 0.0.1 the number must be 1 lower than the actual location
So in the above example for version 0.0.1 the settings are
Night = Enabled
Dimmer = Enabled
Night location = 4
Dimmer location = 3
Time location = 5
Devicename location = 6
With version 0.0.4 this should be changed to
Night location = 5
Dimmer location = 4
Time location = 6
Devicename location 7
Makes sense?
Summary the name of the motion sensor will set how to switch a light.
OK, making more sense now. I was thinking location as in the house lol. Now I see it is the index in the name string of the character.
So, one of my lights is just On/Off so what would I put in the sensor name instead of ‘D’?
I can’t get the light to come on. I have covered the light sensor so it is reporting 7 lux and I have set the start day to be 10:00:00 (currently 9:50). I waited until the senor motion alarm was off and then moved so it triggered but the light does not come on.
My light is a virtual switch as it’s controlled by a gen 2 LightWave dimmer which is not supported by Homey. So the virtual switch triggers automations in Apple Homekit. It was working via the State Control app so I know the switch woks via flows.
Initially my switch was called “Hall Light” so I tried taking the space out and changing the motion sensor name to match but the made no difference.
Keep this page open. Realtime logging will stop when you leave this page.
Date and time
Component
Event
Details
2018-10-28 12:50:29.108
Device Timer
Nl.ketra.devicetimer
Checking for devices to turn off
2018-10-28 12:49:59.106
Device Timer
2018-10-28 12:49:53.034
PIR0N1Hall Light
Alarm_motion
2018-10-28 12:49:50.526
PIR0N1Hall Light
Measure_luminance
1
2018-10-28 12:49:40.629
PIR0N1Hall Light
Measure_luminance
2
2018-10-28 12:49:39.714
PIR0N1Hall Light
Measure_humidity
37
2018-10-28 12:49:29.103
Device Timer
2018-10-28 12:49:11.913
PIR0N1Hall Light
Alarm_motion
true
2018-10-28 12:49:00.445
PIR0N1Hall Light
Measure_luminance
3
2018-10-28 12:48:59.107
Device Timer
2018-10-28 12:48:50.409
PIR0N1Hall Light
Measure_luminance
5
I have set the Start time to 15:00 and the current time is 12:53.
The logger is set to monitor the switch as well but it doesn’t appear to be set.
Just to show that I thought I would log manually switching the light on and discovered that Device Timer will switch the light off (2018-10-28 12:57:29.176):
[Realtime logging](javascript:showPanel(1))
[Configuration](javascript:showPanel(2))
[Performance](javascript:showPanel(3))
Date and time
Component
Event
Details
2018-10-28 12:59:59.192
Device Timer
2018-10-28 12:59:29.111
Device Timer
2018-10-28 12:59:12.929
PIR0N1Hall Light
Alarm_motion
2018-10-28 12:58:59.127
Device Timer
2018-10-28 12:58:41.737
PIR0N1Hall Light
Measure_luminance
2018-10-28 12:58:40.793
PIR0N1Hall Light
Measure_humidity
38
2018-10-28 12:58:32.903
PIR0N1Hall Light
Alarm_motion
true
2018-10-28 12:58:29.107
Device Timer
2018-10-28 12:57:59.121
Device Timer
2018-10-28 12:57:29.723
Hall Light
Onoff
Device Timer
Hall Light is on. switching off
2018-10-28 12:57:29.172
Device Timer
2018-10-28 12:57:03.142
Hall Light
Onoff
true
2018-10-28 12:56:59.178
Device Timer
2018-10-28 12:56:57.254
Hall Light
Onoff
2018-10-28 12:56:47.815
Hall Light
Onoff
true
2018-10-28 12:56:15.575
PIR0N1Hall Light
Alarm_motion
But as you can see it is not switched back on when the sensor triggers.
I already had Prefix set to PIR so I just restarted the app. Now the light stays on
The log is:
Date and time
Component
Event
Details
2018-10-28 13:28:45.832
Device Timer
Settings.set
PIR0N1Hall Light
2018-10-28 13:28:45.619
Device Timer
Device Changed state TriggerMotion
2018-10-28 13:28:45.617
Device Timer
stateChange: PIR0N1Hall Light
2018-10-28 13:28:45.573
PIR0N1Hall Light
Measure_luminance
125
2018-10-28 13:28:44.830
Device Timer
Settings.set
PIR0N1Hall Light
2018-10-28 13:28:44.656
Device Timer
2018-10-28 13:28:44.655
Device Timer
2018-10-28 13:28:44.622
PIR0N1Hall Light
Measure_humidity
37
2018-10-28 13:28:35.375
Device Timer
Settings.set
PIR0N1Hall Light
2018-10-28 13:28:35.169
Device Timer
2018-10-28 13:28:35.168
Device Timer
2018-10-28 13:28:35.145
PIR0N1Hall Light
Measure_luminance
124
2018-10-28 13:28:29.222
Device Timer
2018-10-28 13:28:25.363
Device Timer
Settings.set
PIR0N1Hall Light
2018-10-28 13:28:25.148
Device Timer
2018-10-28 13:28:25.147
Device Timer
2018-10-28 13:28:25.126
PIR0N1Hall Light
Measure_luminance
127
2018-10-28 13:28:15.355
Device Timer
Settings.set
PIR0N1Hall Light
2018-10-28 13:28:15.129
Device Timer
2018-10-28 13:28:15.128
Device Timer
2018-10-28 13:28:15.099
PIR0N1Hall Light
Measure_luminance
119
2018-10-28 13:28:05.388
Device Timer
Settings.set
PIR0N1Hall Light
2018-10-28 13:28:05.181
Device Timer
2018-10-28 13:28:05.177
Device Timer
2018-10-28 13:28:05.082
PIR0N1Hall Light
Measure_luminance
116
2018-10-28 13:27:59.188
Device Timer
2018-10-28 13:27:45.278
Device Timer
Settings.set
PIR0N1Hall Light
So it now seems to treat the luminance change as motion.
On previous changes to the settings I had just hit Save and had not restarted the app.
Just from interest, what is the luminance level that determines night time?
I have also tried to switch of the N field but that has made no difference.
I checked the code, as long as the motion sensor has Alarm_Motion = YEs every update to the sensor will make it seem like it will trigger motion, as soon as its False it will no longer trigger and should be fine.
All seems OK now.
I reset all the settings now I understand what they should be, waited for the motion to turn off, switched the light off and then restarted the app.
Maybe the only issue was not realising the app needs to be restarted after saving the settings so once I had started it with the wrong settings my changes were having no affect.
