Atlantic Cozytouch App
Well, the app is somewhat working. However, it doesn’t detect any compatible devices in my account. I’ve got an Atlantic Explorer V5
I have the same PROBLEM. Is there something I can do to make it work with my explorer V5?
Kind regards Erwin
Edit:
The app is now published and i’ve created a new topic for it.
Hi Nicolas,
This works great for my Explorer V4! I can control the temperature, use the boost or away function with the button, Change the mode with scroll selection, read out the current temperature and set temperature in the insights. I am very happy with this.
Some small things I would like to see as well are: Now the boost or away function can not be started with a flow cards and the power usage is not working in the insights, while this is available in the original cozytouch app. If it is possible to add these features it is really appreciated!
@Nicolas_YDDER
Are you still working on this App?
Hi @AlexRedwood
I will continue to maintain the app. But unfortunately I don’t have other devices to add it. The only solution is to get log or do Pull request on your side on GitHub to integrate code related to new devices.
BR
Nicolas
What is currently working and what not?
Hi all,
New test build: v1.3.1 → Atlantic Cozytouch | Homey
What’s new since 1.2.5:
  • Pass Cozytouch wall modules (ref. 602251) - heating level + on/off
  • Shogun Zone Control : main unit plus each heating/cooling zone, with the zone tiles showing the right heat/cool colours
  • Sauter / Thermor Ipala adjustable-setpoint radiators
  • One global sync interval (default 60 s) replaces the per-device poll timers. Every cycle asks Overkiz for a state refresh, so changes made at a wall remote reach Homey without opening the Cozytouch app.
  • Pairing only asks for your login once; credentials are reused across all drivers
  • New Flow cards for Pass and Zone Control, sharper icons on mobile, French translation fixes
A big thank you to @cedric07 , who contributed the Pass Cozytouch, Shogun Zone Control and Ipala support along with the global sync rework, most of this release is their work. :folded_hands:
Reminder: keep the sync interval at 60–120 s; going lower risks Overkiz QUOTA_EXCEEDED and devices dropping to unavailable.
Feedback welcome: please include your model reference, the driver you paired it under, and what misbehaves.
