[App][Pro] Atlantic Cozytouch Plus
Atlantic Cozytouch Plus — v1.5.2
A quick update on where the app stands. It’s been renamed to Atlantic Cozytouch Plus to avoid confusion with the other Cozytouch app in the store.
What the app does now
Two device types, both paired with just your Cozytouch account — no extra hardware.
Water Heater — works with both Atlantic cloud platforms. The current Cozytouch generation (Explorer V5, newer Calypso, Thermor Aeromax and Malicio, Atlantic Linéo Connecté) and older units on the Overkiz backend, including the Calypso V4 generation. The app signs in to both during pairing and lists whatever it finds. Controls on/off, hot-water setpoint, tank temperatures (top/bottom where fitted), heating modes, Boost, electric-backup status, Away mode, energy and signal.
Air Conditioner / Heat Pump — Cozytouch air conditioners and Alfea Extensa Duo heat pumps. Mode (off / auto / heating / cooling / drying / fan only), setpoint, fan speed, air direction, quiet mode and energy. Heating and cooling each have their own setpoint and limits, and the app writes to whichever applies to the current mode.
Detection is capability-based rather than model-based, so a unit that isn’t listed by name still pairs as long as it exposes a mode or a setpoint. Each device only shows the modes it actually supports — a Linéo won’t offer a Programmed mode it can’t perform. Energy shows up in Insights and the Energy dashboard, and there are 22 Flow cards (9 triggers, 5 conditions, 8 actions).
Changelog
  • 1.5.2 — Added support for the Linéo water heater. Devices now only show the heating modes they actually have.
  • 1.4.6 — Added air conditioners and heat pumps, and made the buttons on the device screen easier to read.
  • 1.3.0 — Added support for older water heaters on the Overkiz platform, such as the Calypso V4 generation.
  • 1.2.2 — New icons and images.
  • 1.2.1 — Various small improvements.
  • 1.2.0 — Added support for more Atlantic water heaters.
  • 1.1.1 — Energy usage now appears in Insights and the Energy dashboard. Values refresh more reliably.
  • 1.1.0 — Improved the device screen and added energy usage.
  • 1.0.1 — Fixed water heaters not showing up when adding a device.
  • 1.0.0 — First release.
A note on testing
The water heater side is validated against real hardware (an Explorer V5). The air conditioner, heat pump and Overkiz support is built from the published capability catalogue but hasn’t been verified on real devices yet — treat those as experimental. If you own one of these and something reads oddly, please reply: with a capability dump I can usually correct the mapping the same day.
Community app, not affiliated with Atlantic. Feedback and bug reports welcome.
!!! Note !!!
Due to the big amount of changes, you’ll have to add your boiler again. Sorry, couldn’t be avoided.
There is @Nicolas_YDDER also working on an apo for Atlantic Cozytouch:
That one hasn’t been working with the V5 boilers from day one and it’s not being updated anymore by the looks of it. Hence the reason i made one.
Hi all,
Really happy to see emulation around Cozytouch here. I have limited access to Atlantic products so I will be happy to open everyone as GitHub contribution to not be the single point of failure.
So I can open access to the code if you want to continue with me the development.
I strongly suggest to avoid multiple initiative for confusion for the end user.
If I have to migrate all my code to yours it’s not an issue at all.
Hi Nicolas,
Are you still actively working on the app? There hasn’t been a reply since April 27th, and the last update was two months ago. It also looks like DHW boilers aren’t working at all currently.
I’m all for keeping things simple, and I’d prefer just one Atlantic/Cozytouch app. Feel free to merge my Cozytouch code — I won’t be actively developing it further, only making occasional improvements, and I have no interest in adding support for more Atlantic products.
I honestly built it just for myself, so I could control my own boiler, but I updated it today and it should now work with all Atlantic Cozytouch-connected boilers.
Let me know what you think.
Best regards,
Hi, I just installed a new Atlantic Linéo boiler. Homey gives the error: No compatible devices found - modelId 1957. Could you please add support for this modelId?"
Next update:
Widgets.
Hello Alex, Nicolas, everyone,
@AlexRedwood @Gerrit_Verschoren
I do not use Homey, but I am investigating the Atlantic Magellan API for the same Linéo model mentioned in this topic:
- Linéo Connecté MP 100L 2250W, modelId 1957, productId 6
Your app description says that Linéo heating modes are supported. Could you tell me which Magellan request or writable capability your app uses to switch this model to Manual mode?
The official Cozytouch app returns the heater from long-term Absence directly to Manual, but a setup PUT with:{“absence”: {}} leaves my heater internally in Away:
  • 288 = 1
  • 312 = 7 (degrees)
  • 337 = 1
True Manual mode is:
  • 288 = 2
  • 312 = 50 (degrees)
  • 337 = 6
Direct writes to capabilities 22, 87 and 226 returned NoCapabilityImplementationFound for productId 6.
I am just trying to identify the exact Magellan request(s) used for Manual mode on modelId 1957.
Thank you so much in advance.
I don’t have access to a Lineo and i’m not sure if i have 100%, however;
Values: "0" = Manual
"3" = Eco+
"4" = Programmed.
After the POST returns an executionId, the app polls GET /magellan/executions/{executionId} until the state is 3.
There is no other request. The app does not write 288, 312 or 337, and it does not use a setup PUT to change the mode as far as i can tell.
For leaving Absence the app does a PUT /magellan/v2/setups/{setupId} with the existing setup fields and "absence": {}, then writes "[0,0]" to the away timestamps capability (222 or 226, whichever the device exposes)
Version 1.8.3 is out.
A device is now only marked as unreachable after three failed updates in a row, so a short hiccup in the Atlantic cloud no longer greys out the tile.
The setting for the meter reading on 1 January has moved to a new internal id to comply with Homey store rules; if you already entered a value it is carried over automatically.
The log line the app writes on every update now also includes the electric element and the hot water availability, which makes diagnostics reports a lot more useful when something looks off.
Special thanks to the user who sent in a diagnostics report; it led to this release.
After the latest update, Homey can no longer communicate with my Atlantic V5 heat pump water heater.
The Cozytouch app is still connected and working correctly, but Homey can no longer access the device or retrieve any data. It seems that Homey can no longer log in to or communicate with the Cozytouch service.
The heat pump water heater is still fully accessible through the Cozytouch app, but it is completely unreachable through Homey.
Could you please investigate whether the latest update has caused this issue and provide a solution?
Have investigated.
The problem lies with the Cozytouch servers. There’s two possibilities
  1. Server maintenance or temporarly overload
    Fix: Just wait. Should be working again in minutes, hours or tomorrow.
If not;
2) Cozytouch waits 15 seconds for an api command, which causes a timeout in Homey. If this is the case, it’s fixed with the update i’m now publishing.
Hey,
Ik zal morgen weer proberen. Het zal wel der Server zijn.
Frank
Version 1.8.8 is out, with better support for water heaters on the older Overkiz cloud, such as the Linéo Connected.
A user with a Linéo Connected reported that temperatures worked but the heating mode and the hot water level did not. Two things turned out to be wrong. The Linéo reports its heating mode, middle temperature, boost and away state under a different naming scheme than the Calypso the Overkiz support was built on, so the app simply did not see them. It now recognises the states regardless of that prefix, and it also reads the remaining hot water on units that report it, so the dashboard widget works for these heaters as well.
The second issue affected every Overkiz unit: the app asked the cloud to refresh the heater’s states every minute, and Overkiz rate-limits that request. The app now asks at most once every ten minutes and waits half an hour after being limited. Reading the values themselves was never affected.
Diagnostics reports now also include a list of every state your heater reports. If you own an Overkiz-connected model and something looks off after this update, a report from the app settings tells me exactly what your unit sends and makes fixing it much quicker. Thanks to the user who sent in the report that led to this release.
Hi @AlexRedwood,
First of all, thank you for this great app!
I have added my two Atlantic water heaters to Atlantic Cozytouch Plus. Both are detected and report temperatures, heating status, and available hot water properly, but neither of them exposes the energy consumption (meter_power / kWh) in Homey or Insights, even though the energy estimation is available in the official Cozytouch mobile app.
Here are the details of my two setups:
1. Atlantic Linéo Connecté (120L) – Connected via direct Wi-Fi (Magellan backend).
2. Atlantic Thermodynamic Water Heater – Connected via a Cozytouch Bridge (Overkiz backend).
I have just submitted a diagnostic report so you can see the raw capabilities and states returned by both devices:
Could you please check if the energy consumption attributes (such as Cap ID 59/57/60 on Magellan and the ElectricEnergyConsumptionState sensor on Overkiz) can be mapped to meter_power for these two models?
Thanks in advance for your help!
Hi, thanks for the kind words and for the diagnostics report, it was very useful.
Your report shows the raw states of both heaters, and neither of them exposes an energy register in the cloud. The ElectricEnergyConsumptionState sensor you mention is not in either list, and both devices are in fact served through the Overkiz backend in your setup (the Linéo as a “modbuslink” device), so the Magellan registers 57/59/60 do not apply to them. That is why meter_power stayed empty: there was simply nothing to read.
What both units do report is their live electrical power (PowerHeatElectricalIn, plus the split into element and heat pump). Version 1.8.9, which I am submitting today, uses that: the heaters get a live power value, and the app integrates it over time into an energy counter with today’s and this year’s totals, so it shows up in Insights and in Homey’s Energy tab. It is labelled “Energy (estimated)” because it is derived from the cloud readings at one-minute intervals rather than read from a meter; in practice it should land close to what the Cozytouch app shows, which is an estimate as well.
Your report also revealed that the V40 value I was using for hot water availability is a running total rather than the remaining volume, so that is corrected in the same release, and your Linéo keeps its remaining-litres reading. If anything still looks off after the update, a new diagnostics report will show me the exact values.
Hi Alex,
Thanks for the quick reply!
All clear on my end. I’ll wait for v1.8.9 to land and test it out.
Thanks again for the help!
Update is live. You can always click the install button in the App Store
