Hi there, am I the only one to be interested with having an Atlantic Cozytouch app ?
Cozytouch is a bridge allowing control of different devices from the Atlantic company. (Heater, towel driers, water heaters etc…). As these devices are connected, it would be great to have these in homey !
On this page you can do a request if there is someone who can build an app.
https://community.homey.app/t/homey-pro-community-app-requests/2713
Please read first what kind of info you have to add to the request.
As an interim / workaround I will be exploring IFFT with cozy touch. Needless to say, I won’t be spending much time on it as the Cozy App itself has for my applicance (Atlantic Explorer V4) very very basic functionalities only
Goede middag in ben op zoek naar een koppeling voor de Atlantic Cozytouch Bridge V2 of is deze er al ![]()
I created a Homey app that supports some Atlantic / Sauter / Thermor products through Cozytouch, using the Overkiz and/or Magellan APIs depending on the product type and its age.
It is heavily inspired by the app developed for Home Assistant by a member of the community.
This is still a very unstable version, and I cannot confirm that it works properly for products I do not own.
At the moment, it is working in development mode for Kelud / ASAMA (towel warmers) and Calypso for thermodynamic water heaters.
If there are any volunteers with some development skills who would like to be alpha testers, you are more than welcome!
Here is the GitHub link → NicolasYDDER/homey-cozytouch. I will try to submit the app to Athom soon.
Hi Nicolas, I have 2 sereins premium towel dryer and would like to support you. I don’t have particular knowledges in coding or else, but with Gemini I was able to implement homey scripts to use my A/C in homey. And it was working. Will follow you on GitHub.
Hi @blutch32 ,
I tried to added Serenis Premium towel heater into the app. I cannot test it directly.
What could be the best approach is to try to launch the app in developper mode (with docker following the readme of my Github) NicolasYDDER/homey-cozytouch
Then the app will appear in your Homey mobile phone and you can add a new device. After authentication to cozytouch login you will see your product.
Then get back to you PC and share to me, from the debug log the modelId our the uiClass + the full log.
We can continue the discuss in private message if it’s simpler
BR
Nicolas Y.
Many thanks for working on this app @Nicolas_YDDER ! I’m looking forward to seeing the Malicio 3 being added to the device list! Thanks
Hi @groteberg ,
I will be really happy to add it to the list of device.
But it’s a resistance water heater (not thermodynamic), it likely uses a different Overkiz controllableName (e.g. _CE_IOComponent instead of _CETHI_V4_IOComponent) and may use different commands (e.g. setDHWOnOffState instead of setCurrentOperatingMode).
If you are confortable to add the app in development mode and get me some logs, I will be very happy to add it.
BR
Nicolas.
Hi folks,
Good news !!! I push test version in the Homey App Store ! Use it carefully !!! It a test version with VERY LIMITED features (even if it displayed 1.2.2)
Objective is to get feedbacks to add more and more devices !
Enjoy !
Hello ,thank you for your update and it disponibility in Homey App Store.I installed your app in version 1.2.2 for my Atlantic Cozytouch AQUEO ACI HYB VM 150l 2200M (this information is automaticaly found by the application )but nothing in the application :
Can you give me a solution for update this information in my Homey Pro
Best Regards,
Hervé
Hi @Herve_Domotique ,
Sorry for the late answer. Could you share me the diag report from the param of the Cozytouch app. It could be helpful to check what is missing as API params.
BR
Nicolas Y.
Hello @Nicolas_YDDER ,
Thank you for your message and taking my request
I made a report from the app and here is the resulting code: ad6e0f76-aad1-4775-b1e3-4436c1b9f38c
BR
Hervé
I cannot find the report shared - with the id : ad6e0f76-aad1-4775-b1e3-4436c1b9f38c
I got the one from @AlexRedwood (investigating).
BR
Nicolas Y.
Hy Nicolas,
Thanks for the Great work! Will the Atlantic explorer v5 200l be supported in the future. For now homey says there are no compatible devices when I want to add my boiler. Keep up the Great work.
Kind regards Erwin
Hi @Erwin_Platenkamp , thanks for your support! The Atlantic Explorer might already be technically compatible, as it is very similar to the Atlantic Calypso (Wi-Fi version) which we already support.
If you’re able to run a test, I’d be happy to adjust the integration based on your feedback and logs.
Best regards, Nicolas
Maybe a stupid question. But i can’t add my device. In the options of the app i fill in my credentials. It says that my account is connected well to the cozy touch magellant and there is 1 device connected.
But when I want to connect my device to homey I select the app and it says there is no compatible device to connect. It doesn’t matter which category I choose from. I fill in the same credentials as I the options of the app. Then it says no compatible devices found. What I’m doing wrong here?
Kind regards Erwin
Hi, I just added your app to my self hosted server, I am able to add the app and configure it.
When I test connection, it tells me that it is connected. When I add devices, it asks me again to login and then find my 3 Sauter Malao heater. But once it is added it is unable to get or set anything on those devices. Any help please ?
