Aqua Temp pool heater
Hi, I am experiencing the same problem, not able to set temperature from Homey.
Interestingly everything seems to work fine for me.
Weird, i just tested again (disabled the homey app for now) from the native AquaTemp app.
Readings are fine (like temperature), but controlling the heatpump fails.
Thank you very much for the link! I can now add my heat pump and read the information (temperature) but I am actually unable to control the switching on and off of the device; same problem with the official application; apparently a general problem?
So it seems yes. I have sent a link to the tech support team. I guess they will solve it tomorrow when they are back in the office :grinning_face:
Your the best! Thanks! :grin:
Have you head anything from support?
Not yet no.
Seems to be working again!
@Jesper_Rasmussen if you could take a look at ‘silent’ mode, would be great.
Thanks a lot!
It does not make any sense to look at silent mode as long as the updated values never reaches to heat pump.
It’s working again now @Jesper_Rasmussen . Settings are being pushed properly to the heatpump. Seems like they fixed the issue with their cloud.
@BoerLowie I am now looking into the silent mode feature. I have the controlling of the heat pump done, but still working on adding flow action cars, so that you can turn it on and off from flows.
I need to add it as a custom capability so it needs some more work.
Excellent! In HA, they implemented it as ‘Fan Mode’ which could be ‘auto’ or ‘silent’ if i recall correctly.
Many thanks.
Hi @Jesper_Rasmussen any progress on the silentmode? If it’s taking longer, no problem: i’ll fire up home assistant again in the meanwhile and control the heatpump through HA.
Thanks!
I will take a look at it again tonight.
Version 1.5.0 is out now. With silent mode. And action cards to turn it on and off using flows.
Super! Thanks a lot Jesper!
Hi everybody.
The original app id has now been transferred to me.
This means that the future releases will be on the original app id.
This is needed in order to release (to go out of the test phase) on the homey App Store as homey will not allow to have multiple apps for the same product.
So you will need to uninstall the test app, and install from the new (original) link.
Sorry for the inconvenience, cause this means that any flows with the old app needs to be updated manually.
The app is now under certification by homey, and will be released as an update to original app when ready. But the test link is already working: AquaTemp | Homey
Cool! Thanks for the efforts Jesper!
So, I’ve been sitting happy with version 1.0.3 fully functioning the whole time while others have had login problems.
Now when the new version, 1.6.0, is released, my old unit doesn’t work anymore. A bit annoying that it’s not possible to enter credentials in an existing unit or the app itself. Had to install a new unit to get it working, as well as transfer all the flows to the new unit.
Another annoying thing with the new version, that wasn’t a problem before, is that you get logged out of the Aqua Temp app when the Homey unit is communicating (hence, always). I still use the Aqua Temp app to set schedule and other things.
