Aqara u50
I would like to get my Aqara U50 door lock into my Homey Pro. But I do not see the Aqara integration listing this lock. Does anyone know another way to get this setup?
Thanks
If it’s not supported by an app/the Homey Aqara app, then it’s not possible to use it directly with Homey Pro.
There might be workarounds via Home Assistant for example, but I didn’t checked.
By using an additional Matter enabled Aqara hub, you can add the lock as Matter device to Homey.
Like this hub:
Are you sure? The U50 smart lock doesn’t support Matter itself or via an Aqara Hub, like other Aqara devices do. iI’s a „clean“ Zigbee device.
I wouldn’t bet my good eye on it of course, Dirk, but the screenshot info concerns the U50.
It’s true almost all Aqara devices are zigbee devices, but,
Aqara invented the Matter-over-thread-over-AqaraHub-over-zigbee construction, to ebable Matter for supported devices like the U50
Zoomed in screenshot:
Hm, seems to be indeed the case, you’re right, I overlooked that, sorry.
