Had high hopes for these affordable matter over thread motion sensors. They paired with Homey Pro but the sensor worked poorly. Returned them. I’d recommend against purchasing these devices at this point.
And in what way did you find out the P2 sensor is the issue, and not Homey’s Matter/Thread implementation? Just curious because the Aqara gear I use is very good stuff.
I only use the zigbee protocol by the way.
But here you recommend the P2?? What’s the plan, Stephen?:
So two different brands of devices and both aren’t working well with Homey. Logic dictates that it might be Homey and not the devices…
One Aquara thread over matter product— the P2 sensor— worked great with Homey Pro.
Another did not. An Eve product didn’t either. I don’t know why. Just telling others about my experience so they can make their own decision.
How do you add these to Homey. In homey there is no P2 version. Only P1 and T1 motion sensor
A little late: I found out that the illumination is communicated only 4 times a day; there are six hours in between the communications? And as far as I can remember the user could set the frequency of the communication.
