Aqara motion sensor disable in flow?
I would like to be able to disable my Aqara Motion Sensor when pressing a button.
But I´m not sure how this can be done, because I dont have any flow cards with the disable funktion like I have with my phillips hue sensor.
Is there a why to do the same with a Aqara Motion Sensor. ?
You need two flows. Flow 1 reacts to the motion detector. Flow 2 is your button and deactivates Flow 1 when you switch it on. When you switch the button off, you reactivate Flow 1.
Aaarrrrr yes of cause thanks alot. :slight_smile:
