Today i added the FP400, same Situation like the guys above reported, no zone names will be transmitted over Matter protocol, this brings confusion if you create all zones at once in the aqara app because in the homey app you cant see any differents, the zones will be listed with Presence alert (1)..(2)..(3)
So i recomend to make a zone in the aqara app, sync this zone and give them a notice in the homey app, after this repeat this procedure as much zones you need…
One further information which i dont know, this screen (pic.below) you only get if you have no aqara hub in your system installed, in my case it was and so i never get this option because the aqara app always want to continue with the hub! First i had removed my hub (Cam Pro G5) from my aqara account i get this screen and could continue like the description below…also keep in mind you need for this step a Thread Mobile Device, i used my iPhone Pro15, this model had Thread onboard!
The underlying limitation is in Homey’s Zigbee implementation, so I can’t fix it at the app level. Athom has acknowledged it and added it to their roadmap, but hasn’t provided an ETA or confirmed whether a solution will be possible.
At the moment, I can’t get detection zones configured through Homey over Zigbee. In my testing, without those zones, the sensor doesn’t report presence, which makes it of very limited use with this integration for now.
Yesterday i installed new FP400 Firmware, v1.2.0.0, Homey itself does not recognize that a new software is available, not in the Homey App on iphone (Settings->Device Updates) also not under the Device Maintenance Settings “Search for Update” Button.
Well i decide to make it over the Aqara App, the Updates runs through without problems, i decide further to test the other way for integration of the sensor into Homey, made factory reset and go the way over my G5pro Cam which is a Aqara Hub as well, the matter controller is still homey and my G5pro Cam and the sensor are part of the Homey thread network, the benefit of this is that you have access from outside and should have more options (can’t confirm) inside the aqara app, if you don’t need it you can go the directly way like i had described above as well. Regarding the zone names are no changes…but the zones are working under Thread an could be programmed in the flows…
Aqara is kind of bad with publishing Firmware via the official Matter update ledgers… So this update would also not show up via other 3rd party controllers. I really hope they improve in this regard in the future.
As we know, the zones do appear in Homey, they are just named Presence Alarm (2) or Presence Alarm (3). If you take the time to figure out which is which, you can still write flows that trigger on these. It’s just not very intuitive reading the flow. What makes it even more confusing is there are multiple Presence alarm turned on When cards to pick from and you have to use the cards with duration (I used 1 sec).
The main Presence sensor (room) works with the regular Zone becomes active card.
Since the FP400 works with Apple Home (including zone names) , a silly workaround if you have Apple Home is to:
1). Create a Homey virtual switch for each zone. Mine are Couch and Loveseat
2). Sync the virtual switches with Apple Home using HomeKitty
3). Create Apple Home automations for When Occupancy Detected (by the zone), turn on the Virtual switch and a second automation for When No Occupancy Detected (by the zone), turn off the Virtual switch.
4). Then you can create Homey flows triggered on these virtual switches. When “Couch” is turned on, do something. They just don’t work quite the same as true presence sensors.
