Aqara Cube only some times reacts how to fix
The distance between between the homey pro 2019 and the cube is +/-2m.
How van I fix this?
Did you replace the power brick already? Some deteriorate over time, causing the output voltage to drop; noticable by zigbee functionality becoming fuzzy
Else it might be suffering from interference
