Aqara compatibility
Hello, i have had conflicting research with regards to compatibility with aqara devices. Can anybody please tell me, is it worth getting the homey pro or just sticking with an aqara hub!? Any info would be awesome
And you are asking on the Homey Community….
Maybe be more specific about you concern and the conflicting research answers.
First of all, welcome to the Homey Community!
To make sure you are aware of the forum rules, please read the Welcome to the forum! post here.
My very bad experiences this year I cant support Homey anymore.
Waiting for a fundamental solution in an answer on my letter from the developers.
It’s holiday periode so I know that it can take longer to react.
I am wanting to use the aqara gu10 however I have read in a Reddit forum that the t series struggles with the homey hub.
I am wanting to use the lamp as part of a flow that resembles the sunrise in the mornings at 3000k then work through the range up to 6500k and back to 3000k for sunset for the winter routines.
Before I buy a homey hub I was wanting to confirm this is possible and has anybody else set up the lights like this
I don’t personally have experience with Aqara lights. I do have several other T1-series devices: door & window sensors, water leak sensors, light sensor and temperature & humidity sensors.
I have been using them for a year now directly connected to my Homey Pro 2023 in conjunction with other Aqara devices (including the prior non-T1 version of those sensors) and Zigbee router devices from others brands (mostly INNR and SONOFF). I haven’t run into issues (knock on wood :sweat_smile:).
Note that, before you buy a device, it is worthwhile to check the supported Aqara devices on the Aqara App Store page and in the dedicated section in this forum: [APP] Aqara & Xiaomi Smart Home - Simplify your life with a smarter home .
Not all devices may be supported and sometimes certain capabilities of a device are not supported. Check the first post of the linked forum topic for more details on which devices and capabilities are currently supported.
About Aqara lights ?
Guess that is the topic here created by @Sam_Brown .
About the working model of Athom with Homey.
Counting for every one.
