Aqara Automation into Homey Pro Advanced Flow
This category is created to show, and explain the working of specific Flows in homey.
Hey Guys, I wonder if you can help me with this!
So above is an automation i had working perfectly on Aqara, but im now putting everything over to Homey Pro. So, i am trying to figure out if theres a way to do this.
So to explain, when i press the RIGHT button, AND the LEFT button is ALREADY ON, THEN do this…
It seems with homey pro I can only say ‘turns on’ twice.
Any advice, or can some one show me how i would do this?
I am not sure what device you are using, nor which flow cards are available for this device. However, often in Homey you can reverse a WHEN or AND flow card action by right clicking it and choose the reverse option in the context menu. So ‘is turned on’ would become ‘is turned off’.
you have to do this a little bit differently in homey indeed. But you pretty much explained already yourself how you should make the flow:
“So to explain, WHEN i press the RIGHT button, AND the LEFT button is ALREADY ON, THEN do this…”
Hey guys, i ended up figuring it out by using logic :slight_smile:
