Thanks!
When I try to track an airplane registration (PH-XXX) I get an error (Timeout) Is this a known issue?
Not known to me. Ill look into it. Thx for the feedback!
New version coming up v3.2.0
- Fix http(s) timeout.
- Update capture logs.
- Brand color added.
- Readme.txt added.
@ECort here is how you can share your counting flows:
You can post the links here and add a description
Ha Robin,
I did my best to share my setup.
Personal note
My primary interest concerns the (crazy) number of flights over our area. Seems that ât Gooiâ alone âtakes careâ of 60% off all Schiphol Noise (300-400 overflying flights/day) to average 500 flights/day Schiphol. Every runway use brings flights over âT Gooiâ- there is no escape. Only certain weather confitions help to eleviate noise here. But noise is here every day and every hour. This not healty. The âclimbâ adjustment to 10.000 ft (start 2019) als means âflights climb tot 30.000 ft as from ât gooiâ with a lot of noise (maybe some day I will built a calculation on âmean altitude for incoming and outgoing fligthsâ.
It seems to be working rather correctly and reliably. REMARK: we also have a lot off âlocal flightsâ from local small Hilversum (general aviation) airport wich are not counted by the source and are missing in the numbers. So actual numbers are even higher.
The statistics on âNoiseâ are new and needed some tweeking. Itâs seems to be working correctly.
I think you built a very important and helpful app for a lot of cities in the Netherlands. Now people can build personal statistics without BAS wich give âgeneral picturesâ. With your app (and applied calculations) every city in the Nehterlands can calculate flghts, duration and ânoise in generalâ. HOMEY could sell this as a product âHOMEY-Flight counterâ . But a website from Virtual Radar for all cities in the Netherlands I think would also serve a lot of people or environment organisations.
VARIABLES
(Did not find easy way tot display full name of variables. So here difficult screenshots to solve that. All my variables are in Dutch.
Calculate nr passing Aircraft overhead per day
- Each âentering airplane into airspace overheadâ is a +1
- Cumulative counter starts at â0âeach day and count at the end of the day is stored
- Nightflights are determined separately from 23:00-07:00 hours (with overlap on âday totalâ).
<img width=â198â height=â33â style=âwidth:2.0625in;height:.3402inâ id=âAfbeelding_x0020_6â src="//discourse-cloud-file-uploads.s3.dualstack.us-west-2.amazonaws.com/business4/uploads/athom/original/3X/5/b/5b23a6a50762a97d9a4153bf343bca7f030fe078.jpeg" alt="Afbeelding met tekst
Automatisch gegenereerde beschrijving">
Calculate nr passing Aircraft overhead actual (Creating noise)
- Variable is shows if aircraft are actually passing overhead (Creating noise)
<img width=â200â height=â30â style=âwidth:2.0833in;height:.3125inâ id=âAfbeelding_x0020_5â src="//discourse-cloud-file-uploads.s3.dualstack.us-west-2.amazonaws.com/business4/uploads/athom/original/3X/e/9/e9c1727bd2f11b544dc712fcd9d758e58fe8e765.jpeg" alt="Afbeelding met tekst
Calculate nr seconds Aircraft overhead per day (creating noise)
- Use âHOMEY-Countdown appâ to count down from âtotal seconds per day during âpassing Aircraft overheadâ (Creating noise).
- Used âIOS-Explane appâ to determine DBâs. Average=50DB for Climbing & Ascending aircraft)
<img width=â198â height=â37â style=âwidth:2.0625in;height:.3819inâ id=âAfbeelding_x0020_4â src="//discourse-cloud-file-uploads.s3.dualstack.us-west-2.amazonaws.com/business4/uploads/athom/original/3X/1/1/11fc8296210731dbb0ec1eec9ce0045ff6cfa5d0.jpeg" alt="Afbeelding met tekst
FLOWS
https://homey.app/nl-nl/flow/m6Xt2K/ (Cumulative flights +1 continous (no-end))
https://homey.app/nl-nl/flow/Qlyw2K/ (Set Cumulative Day start at 00:00 from Cumulative count)
https://homey.app/nl-nl/flow/awLw2K/ (Set Cumulative Day end at 23:59 from Cumulative count)
https://homey.app/nl-nl/flow/3sSt2K/ (Set cum flights on 23:00 hrs for nightflights)
https://homey.app/nl-nl/flow/a0ku2K/ (Determine nightfligths at 07:00 (Start 23:00 previous day))
https://homey.app/nl-nl/flow/hNtu2K/ (+1, value >0 means âflights overheadâ (Creating nois))
https://homey.app/nl-nl/flow/Hrxu2K/ (-1)
https://homey.app/nl-nl/flow/nPBu2K/ (Signal YES-flights overhead (garden lights go on))
https://homey.app/nl-nl/flow/AXGu2K/ (Singla NO-flights overhead (garden lights go off)
https://homey.app/nl-nl/flow/5KQu2K/ (set countdown per day counter)
https://homey.app/nl-nl/flow/gPWu2K/ (start countdown when flights overhead)
https://homey.app/nl-nl/flow/LH0v2K/ (stop countdown when no flights overhead)
I hope itâs complete. It should help you understand my setup/logic.
Kind regards,
Eric
