If you are willing to share your Rapid API, contact me via PM and I can have a look however I’m not going to invest into it myself
Hi Sharkys,
Thanks for your reply. I have made an Opensky account, made a tool based on this, it’s active, but it is not possible to add a tag to a flow. The many tags are shown, but unselectable.
Now I obtain all targets within a selected range, but without tags, I cannot filter these. Any idea?
Yes off course IF must be WHEN…
But thanks, adding the LOGIC is the trick!
Hopefully the fog will disappear these days, so I can check the working.
Regards,
Wout.
Just FYI: most When (Als) cards do not function with tags as value
I have learned this for now, thanks also.
People are using this? Trying to use the OpenSky login with my feeder id but this gives a 401 error
401 error means: Incorrect API key provided … are you sure you are using correct one? if so, submit debug log
Where to fill in the API? I login using my username and password and add my feeder id next to it? Debug made: 5bf73b9d-3659-4e4d-94c2-6e92490ff68f
Ah, you are right, let me check later, will have a look on logs
So it seems that new users must start using API instead of login name and password. For existing users nothing is changing so far… when you login on OpenSKY Sign in to Opensky Network, you get :
So I cannot use the app I guess?
I’m working on new version, already having working version available but testing… hopefully today I will release TEST.
@HScholing please test…
Version 3.3.0 — New logo + OpenSKY OAuth2 support.
Great! I will test it then
Thanks!
Unfortunally no success: after filling in my API credentials (had to reset first to get a secret) I get a success message. But when I close this I receive the following: Error: Missing Parameter: device.data
I don’t know what is meant with this as I cannot fill in additional fields. There is no difference when using my feeder serial id. Hope this helps with the testing. Debug report: 4d7050f9-9fd1-4fb5-b2df-6f9831ad42d1
