App request KPN Settopbox ARRIS 2952
What kind of device would you like to be added :
•KPN settopbox ARRIS 2952
What kind of category signal would the app use :
•IR / modulation frequency 56 kHz
Is there a (public) API / documentation or known other implementations (like Blogs/Github etc)
•https://gist.github.com/proycon/d8f730bb47ff6d7eaa12
•https://github.com/athombv/nl.kpn.ir
Are you willing to loan or donate a device to a developer?
•If really needed: Yes
@JaVri I think I have the same device (although I control it with the Logitech Harmony Hub) I will see what I can do.
That would be very kind.
I now control it with a flow in the Harmony One; with one touch I activate the Arris, activate a Philips soundbar and activate my Philips TV (all to the right channel and HDMI-port).
But I’d like to do all of that with my Homey.
If you own the Logitech Hub you could also use: https://apps.athom.com/app/com.jreenen.homeyharmonyhub to pair those devices and use Homey to control those. My personal experience is that the Logitech hub provides better results in IR signals but that might be because of where I placed my Homey.
No I don’t own the Logitech Hub. I hoped I could operate them without having to buy another hub/bridge/etc.
@JaVri You could also try and learn those signals to Homey itself by using the IR Device under Homey. Thanks @Emile for learning that you have that functionality
@jreenen: should I press every button on the remote to ‘learn’ them to the Homey? Or is pressing some buttons enough to learn the remote to the Homey?
To be honest I haven’t used it myself but I would guess if you press a random button homey will guide you through the rest of the procedure.
Any updates yet? I am realy waiting for this to be supported.
@JaVri @HarmJ Well, almost 3 yrs later, some good news :crazy_face:
It is available as of v7.2.0 and also available @ Homey bridge.
Add new device > Homey > Infrared
Enter arris at the search bar
Pick the 2952
Tnx! Problem is that I now have the 4k receiver and that one is not supported :rofl:
In 3 years it probably will!
Hint, try a few Arris remotes and KPN Arcadyan. Maybe you can use 2 or more different devices to control the 4k box.
Like device A for powertoggle
Device B for volume
device C for channel, you get the idea.
:x::put_litter_in_its_place::wrench:Well appearantly Arris VIP2952 doesn’t work anymore since 6 months? The on/off commands of today aren’t even getting registered
Didn’t notice it before b/c I fiddle a lot and use RM mini3 & Tuya IR blasters.
Also my Yamaha RXV630 doesn’t respond since then.
Homey IR still works, while my Marantz responds fine…
Is it me? Or…
Could you add support for the 4K STB: Arris VIP5202 ?
This is the default STB send out by ISP KPN
