Reolink v1.6.2 is live
Install: Reolink | Homey
v1.6.2
- Cameras behind a hub or NVR get their own motion detections, even when a channel on the hub is empty.
v1.6.2
Anyone can help me?
@Fant4 Have you tried changing the stream to the sub-stream?
H.265 CODEC isn’t supported by the WebRTC implementation that Athom uses for Homey.
SOLVED: WebRTC offer failed – 404 page not found (Homey SHS)
I finally managed to solve this issue, and I wanted to share the solution in case it helps other Homey SHS users.
All my Reolink cameras suddenly stopped working in Homey, showing a black screen with the following error:
WebRTC offer failed: Not Found: 404 page not found
The cameras were still reachable and working correctly through the Reolink app. The problem affected all cameras, and restarting or updating Homey and the Reolink app did not resolve it.
Root cause: The bundled go2rtc version was 1.9.13.
Solution: I replaced the bundled go2rtc binary with the official 1.9.14 release, then restarted the Homey SHS Docker container.
After the restart, all my cameras started working again!
For reference, the binary was located at:
/app/packages/homey-local/assets/bin/amd64/go2rtc
I downloaded the official Linux AMD64 release from the go2rtc GitHub repository, verified its SHA-256 checksum, backed up the original binary, replaced it, and restarted the container.
Important: This was a manual workaround in my installation. The replacement may be overwritten by a future Homey SHS update, and I recommend backing up the original binary and verifying the correct architecture before attempting the same procedure.
Hopefully, this helps anyone experiencing the same WebRTC 404 error!
Reolink v1.7.0 is available on test
v1.7.0
