[APP] Qubino - Turn any home into a smart home with Qubino
To be clear, do you have the special Qubino temperature sensor?
If yes, is it connected to the special connector for this sensor TS? Like this?
What is connected to the “Input” of the Qubino-dimmer:
How do you set the fan-speed, do you use a push-button or a switch or something else?
Be aware that this setting is only for a temperature sensor connected to the “input” connection.
Sorry, you’re misunderstood, probably on my part.
I’m NOT measuring a temperature. My Qubino is attached to a motor that controls an air-valve. When the controlvoltage is 0v the valve is closed, when the controlvoltage is 10v the valve is open. What I want to measure is the valveposition
The motor has a feedbacksignal (B), which also measures (or reports…) 0-10v. So, when I set the dimmer to f.e. 5v (A), the motor will slowly move the valve to 50% and report the valveposition back on the feedbacksignal with 5v (B), attached to the left port on the Qubino
I want to display the valveposition in the Homey device
On my Homey 2019, this displayed the valveposition in 0-10*C in 0,1 increments (so, a “temperature”), which is fine. Because it’s a valveposition, 0-100% would be “ideal”, but again, this was fine.
When I set the Homey device on my Homey 2023 to below option;
then I need to re-add the device as stated (on the settingspage), but then I get a 0-1*C reading, in 0,1 increments, which is 10 times less accurate.
The other options don’t seem to work.
So, what settings do I need on the Homey device to display 0-10*C, or maybe even 0-100%? Because I need to re-add the device for every change I make it’s very cumbersome to test all settings.
I hope you understand now.
More understanding now :slight_smile: Looking at the manual, the I1 input parameter settings are 140 up.
I saw this (this parameter is associated with the association group no. 2),
maybe you have to set this also (mostly this is in the advanced parameter settings).
Thats all I can think of, I don’t have this module, so I can’t test unfortunately.
It’s my only Zwave device, I really don’t understand what you mean. Are group associates not something for multiple Zwave devices?
How would this setting change the readout value?
It’s like opening a second channel, if it is not used, it does not harm.
