[App][Pro] ZoneTracks
I did some further testing.
OwnTracks Android (420509001) in HTTP mode always gets “400 Bad Request” (Express error page) from the endpoint. Same POST via curl gives 200 with Content-Type: application/json and 400 with Content-Type: application/json; charset=utf-8, which is what OwnTracks sends. Headers x-limit-u/x-limit-d are present. ZoneTracks version: 2.5.9, Homey Pro SHS: 13.5.2
Can you double check the username and password is completely blank in OwnTracks?
They were blank.
I just switched to MQTT to test that. That’s working, but it adds a new layer of complexity that I rather avoid.
Apparaat-ID Husky
Tracker: ky
Is this correct?
They are not critical for the Homey app, so you can set them to anything you want, but for OwnTracks they need to be unique per user.
I use Homey SHS and this link
https://homey-%homey-id%.connect.athom.com/api/app/com.ady.zonetracks/events/mickey
Reinstalled both apps.
But no result. I hope you know a solution
Have you had a chance to test the app on Homey SHS?
Sorry, not yet. Work has been manic lately, so late home every day. My SHS needs to be set-up again, so it’s not a quick check unfortunately. I will do my best to try it over the weekend.
