Guys, is there a tutorial or video showing how to configure and install the Zigbee 2MQTT and its devices? I’ve been reading the posts and found them a little confusing.
Noticed events in my logs since today, originating from homey.
It seems the zone activity started working, so l looked up the changelog for this app and noticed it got added.
Nothing was bound to it anymore though as i already moved back my automation to node-red and my homey mainly operates as expensive 433mhz bridge at the moment.
Just hopping in here to say great work on having this operational!
Hey there,
I’m very green here so please be gentle.
I’m trying to use Zigbee2MQTT and z2m rather than the native Zigbee function in Homey, because I have 20 new Zigbee lights already installed and it looks like this app can help pair a few at once.
I’m stuck on identifying my Homey Pro as the “adapter” port in the Zigbee2MQTT config and I dont have any other Zigbee hubs to use instead.
Thanks for the reply.
Sorry I should have clarified… I am running z2m and mosquito on an Raspberry Pi… I’m at the final imlementation but don’t know how to port Homey Pro in z2m on RPi…
I have tried using the Homey Pro IP address but it can’t find it.
Sent a donation, but the change I asked for is not really that important, spend it on beer instead of a mwave device
If you happen to have any time over, you could please add so that you can change the state of channel 3 and 4 of these 4 channel device (you can only change state of 1 and 2).
I have a zigbee power plug for the light in my attic. This is connected to the homey via Zigbee2MQTT and the zigbee2MQTT app. The MQTT runs on a PI.
Since today the light turns on by itself, wihout any command.
Looking at the homey log it says : Turned on by Zigbee2MQTT.
I have looked in the MQTT log, on the PI, but it just says
Info 2024-06-06 12:58:58MQTT publish: topic 'zigbee2mqtt/Zolderkantoorlicht', payload '{"current":0,"energy":3.73,"indicator_mode":"off/on","linkquality":124,"power":0,"power_outage_memory":"on","state":"ON","voltage":229}'
But the actual source of the action cannot be determined here.
So I have no clue why the light randomly swichtes on.
Any similar experiences and ways forward ?
Thanks Theo
