We’re investigating a Zaptec Go where charging measurements appear to freeze in Homey while the charger remains available and reports “charging.”
During seven checks over approximately two minutes, these values remained unchanged:
Power: 4,754.52 W
Phase 1 current: 22.22 A
Session energy: 4.937 kWh
By the final check, the power value’s lastUpdated timestamp was over four minutes old. The session energy counter was also not advancing.
We understand that the timestamp and reported values are only updated when there is a significant change in the measured value. For example, if charging power changes from 4,000 W to 8,000 W, the new value is reported immediately. However, if the charger remains stable at approximately 48,061-48,068 W, Homey may continue to show the same value and timestamp for an extended period, potentially several hours, even though charging is still active.
Power Guard 1.3.9 reads the Homey device every five seconds and receives the same values. We also checked the Zaptec device directly through the Homey API, outside Power Guard, and saw the same unchanged readings. The Zaptec Homey app was running and reported no crashes.
The installation’s available current was set to 32 A. We did not change settings or send charging commands during these checks.
This suggests the measurements stop updating somewhere between the charger, Zaptec Cloud and the Homey integration. We have not yet compared these readings simultaneously with Zaptec’s own app, so we cannot identify the exact point of failure.
Has anyone experienced this with version 1.13.0? What update interval should we expect for power and session energy during charging, and which logs would help determine whether polling or cloud telemetry has stalled?
