Hello, is it possible that the power consumption of the Zaptec Go2 is also visible among the power consumers in the energy tab? I only see the charging station on the 3d drawing of the house but no power consumption in the list.
Subject: Homey device view for Zaptec charger resets Charging Mode to Default
Homey: Homey Pro (Early 2023), firmware 13.5.0-rc.4, Homey app 10.1.1.2098, local connection
Zaptec app version: 1.10.4
Installation: 2x Zaptec chargers, Sense load balancing enabled
Bug: Opening a Zaptec chargerâs device view in the Homey app (main view, not settings) causes Charging Mode to flip from Automatic â Default in Zaptecâs own app, within seconds. Affects both chargers in the installation.
Repro:
Set Charging Mode = Automatic (verified in Zaptec app)
Open charger device in Homey app (any tab except settings/gear)
Switch back to Zaptec app â Charging Mode now shows Default
Not affected: Reading the same charging_mode capability via Homey flows/API (HomeyScript getDevice(), polling) does not trigger this â confirmed by running automated 15-min polling flows without any mode change. Only opening the device page in the Homey app UI reproduces it.
Impact: Sense load balancing is silently disabled every time the device is viewed in Homey.
Dear Patrick,
I am one of the testers of the Homey Pro app SlimLaden, focussing on the EV charging functionality.
Although SlimLaden now offers a âSolar onlyâ option for EV, Zaptec chargers currently appear to be controlled as on/off devices only. In the past, I created my own Homey flow that dynamically adjusts the charging current based on the available solar surplus, allowing the car to closely follow the available PV production.
However, I would prefer to have EV charging and home battery charging integrated and coordinated within SlimLaden.
I asked the developer of âSlimLaden Thuis en Autoâ, to see what would be possible.
His suggestions:
And your actual requirement â dynamically adjusting to the available solar power, as in your flow (6â16 A): your flow can do this because it uses the Zaptec appâs âSet available currentâ Flow action.
SlimLaden controls devices through their capabilities, and in the Zaptec Homey app the current limit (available_installation_current) is read-only â it can only be changed through that specific Flow action. As a result, SlimLaden cannot control it directly.
The proper solution would be to ask the developer of the Zaptec app (patricke94) whether he could make this current capability writable. Once that is possible, SlimLaden will be able to provide exactly the adaptive solar-following behaviour that you have currently implemented manually â the current control functionality is already available in SlimLaden.
Would it be possible to add this functionality to the Zaptec Charger app, while keeping the existing functionality unchanged?
Or do you see other options to implement an only solar charging option with the Zaptec Go 2?
Thanks in advance for your support.
Best regards, Jan
Hi Patrick,
In the meantime, I contacted Zaptec. They checked my installation and manually updated my Zaptec Sense, enabling me to use solar surplus charging directly through the Zaptec app.
I have two requests for the Homey Zaptec Charging app:
Make the charging current capability writable. Would you still be willing to look into my earlier request? This would allow me to adjust the charging current from Homey and provides the desired integration with e.g. the EV Charging app.
Add a Flow card to select the solar charging mode. Zaptec offers two options:
- Surplus only: charging using only surplus solar energy.
- Surplus + grid: charging using surplus solar energy supplemented by grid power.
Would it be possible to make both modes selectable through a Flow card? This would help me integrate Zaptecâs solar charging functionality into my existing Homey energy management setup.
Thanks in advance for considering these requests, and for your continued work on the app.
Best regards, Jan
Hi everyone,
If a few of you are feeling adventurous it would be great if you could try the testing release Zaptec | Homey . Especially if anyone has got the Sense. I donât have one myself, so itâs been guesswork trying to include it.
Any feedback is welcome. Sorry for the slow iterations.
Best regards, Patrick
If iâm trying to add the Sense (which i can choose in the add new device applet) it canât find any new devices after i logged in with my Zaptec credentials.
@pwad i have the same probleme
Could you try to pair, then exit and go to the app details page under settings and trigger a diagnostics report. That would be valuable! Thanks
4a8f3d76-0346-4dfa-9caf-51056e231624
d6195b60-85d2-49cd-ab75-9774fd48989a
Installed v1.12.1, but unfortunately the Zaptec Sense canât be found.
Unfortunately the same problem after updating.
If you could please press send diagnostics report after trying the failing pairing. Otherwise Iâm flying blind here and only guessing.
Hi Patrick,
Just tried again. See: 0065cfb7-87fe-445a-b11b-7d1457f2a420
Best regards, Jan
a291a4f6-23e3-4134-be1e-4b0ec3c7f4b6
sorry
Hi @patrick
Do you have a rough timeline for when you plan to release the Zaptec test app for Live?
Specifically, Iâm referring to the version you currently have in your test channel.
Weâre developing Power Guard and need to make some changes to support the new app. Since we need to release our production version at the same time as the Zaptec app goes live, it would be very helpful to coordinate the timing and plan our testing accordingly.
Thanks!
Just tried again, unfortunately still the same issue. 1a9ec838-f3c9-41a0-b034-94b51b44e1fa
No specific plans, but I aim to do it this week. Any time that fits you better?
