I am still working on some issues with X-Sense. Now I got a response from x-sense support but I got only time on weekends for coding and testing
If you want, you can share your x-sense with me and I will dive deeper into it. I will send you my e-mail address for my x-sense developing account, if you want.
As of today, I have 8x SC07-WX CO/smoke detectors connected to Homey.
The only thing that doesn’t work is the battery indicator and the Wi-Fi signal indicator.
The SC07-WX does not support temperature and humidity, so this information is not displayed either.
However, this is not a problem for me, as I get this data from Home Assistant.
My two cats hate the beeping of smoke detectors and almost go crazy. Does the X-Sense also start beeping during a test? If so, I would rather do without a Flow with a test run.
I have the issue that the XS01-WX sensors are not displayed in the Homey app.
This is what I did:
Installed the sensors in the app
Created and confirmed a second account
Sent an invitation to the new account from the main account
Confirmed the invitation in the new account
Then I created a new device in Homey, selected the sensor type(Rauchmelder), and logged into the account. The display briefly shows that new devices have been found, but the pop-up screen immediately disappears again (after about 1 second) and the devices are not created.
I have assigned fixed IP addresses to the sensors.
Tested again. 60683b09-d884-48c5-b436-e7734cc72fea
In device settings I can’t set the device in fire drill mode. And as mentioned before, I can’t select a device in the then card "test the alarm of’
In settings, the device id’s arent filled. Is it possible that’s the problem?
