[APP][Pro] WhatsApp - Simple. Reliable. Private
No, i did configure it, and it has a device in Homey. I can use that to send a message from the device to what to the group, that works fine. But i cannot get the widget to display anything yet…
@Nastybaloo so is the number you configured in your homey part of the group which you want to display on the widget?
Yes, it is… But it was Fault 40…Sorry for that. Im th eidiot, i forgot to put the updated 4 digit code from the widget in the chat in Whatsapp… Now it works, thanks. I will name my next 3 children after you
@kooskortekaas
Yes this is possible. Therefore you need to get the group answer code.
Use the if card “New Message” and the Then card “Send Message” in the then card use the tag answer code.
Now send a message to the group of your liking where you homey account is part off. Then you’ll get something like this 1234567@g.us . This you can use to determine the group.
Nice! :laughing:
@martijnpoppen I have the following behaviour, is that expected? Or is the repair flowcard not working
1 app not updated yet, but my pairing code is expired (I left it that way to test the update)
2 updated the app to 1.28.0
3 waited
4 next day it showed an error in the timeline (good!)
BUT
I had also created the following flow:
This flow has not triggered yet…
Is that correct behavior? (It only triggers at the moment the pairing code becomes expired, and mine was already?)
Request:
Can you also make a AND card with the check?
I would like to have the message at a specific time:
WHEN: 00:01
AND: a new pairingcode is needed
THEN: send a message
@FKey it gives this when you start the app. But probably it didn’t work on install as the card was not there yet
I will check the AND card if it’s possible
@martijnpoppen,
When sending a message it has as input: “Mobile number / Group invite link”.
Why not extend the text with “/ Reply code”?
I discovered (after diving in to this forum, the source code and logging all parameters to a google sheet) that you can also use the Reply code / replyTo / remoteJid as recipient.
For me there was some guidance missing on what to do with the reply code.
Btw. Thanks for this great App!
@bobvanoijen because the reply code only exists if you use the message received card
So when you are only using this app to send messages that might be really confusing
I tested it by restarting the app again, works fine I received the push triggered by the new card.
Thanks
For me it sounds logical that you only can have a reply code when your replying to an earlier message.
It just wasn’t clear to me how to use the reply code.
In particular, because it only said “Mobile number / Group invite link”.
@bobvanoijen I can add it to the hint. Or feel free to create a PR :smiley:
It would be a great hint!
Creating a PR from my phone right now is a little hard…
Thanks for you quick response.
Hi @Hagen
This is an English topic. So please translate your post accordingly so everybody can read along
PS: I don’t speak German either
Sorry!
so here is the request via translation program:
Hello Martin,
I send Whatsapp messages from my cameras with a picture to another account that runs the Homey Dashboard. Unfortunately, the Whatsapp messages arrive on the dashboard without a picture, only the text is displayed. Can you help me?
Best regards, Hagen
@Hagen can you elaborate with a screenshot so I understand what you mean?
I reprogrammed everything again today, the Homey Dashboard WhatsApp function only receives texts, but no snapshots from my cameras. Maybe it’s because I used a landline number for Whatsapp. Maybe the sending of snapshots only works via a cell phone number.
Best regards, Hagen
@Hagen can’t say that without more info. Please show what you mean
When I have loaded and activated the WhatsApp app on the Homey, I no longer receive notifications on the mobile phone (iPhone). I don’t get a message on the lock screen and there is no sound when I get a new message. All notifications are turned on.
Is there a solution for this?
Translate with Google.
@Limofant yes try to send a message once from WhatsApp on homey and it should work after that
