[APP][Pro] WhatsApp - Simple. Reliable. Private
@Houtwoud same solution applies then. Remove and re-add
Ik krijg in de groeps app een melding “one memeber use old whatsapp version” en dat is alleen in de groep waar homey ook in zit, hoe kan ik whats app op de homey updaten?
If you could please keep the conversation in English as much as possible, then more people will be able to participate and help you. Please translate your post into English, otherwise it will be deleted in three days to keep the thread in just one language as stated in the forum rules Welcome to the forum!
Please do also check out the categories in other languages:
Dansk (Danish)
Deutsch (German)
Español (Spanish)
Français (French)
Italiano (Italian)
Nederlands (Dutch)
Norsk (Norwegian)
Polskie (Polish)
Suomeksi (Finnish)
Svenska (Swedish)
If you need help, because depending on the trust level of your account, you may have limited permissions, please PM me or another moderator or reply to this post.
@Apeldoorn_GvAC no you cant
But it works right?
Yes, that works. Drawback is that I need to rebuild my flows with all the whatsapp cards again. Any ideas how to fix that?
@Houtwoud You can repair them with: [HOW-TO][Pro][Cloud] - Tool to FIX (advanced) flows after removing and re-adding devices
@Bjorn_Schalks thanks for sharing
I will look into the repairing though
New app update (:orange_square: TEST: 1.28.0):
Changelog:
NEW:
1: NEW: add pairing code reminder flowcard
2: NEW: add timeline notification when repair is needed
FIXES:
1: FIX: repair mechanism
More - apps - Whatsapp - settings wheel right top - send diagnostic report (put your email in the input field to make it easier)
Issue list: [APP][Pro] WhatsApp - Simple. Reliable. Private - #3 by martijnpoppen
Is it possible to create an AND card to select the specific group where the message is coming in?
@kooskortekaas No it’s not possible to determine the group
Oke, too bad.
I get a message in the group app “a member is using the old WhatsApp version” and it’s only in the group where the home is also, how can I whats app for the homey update?
@Nastybaloo thanks for translating. But I already replied to this message right….
:hugs: My pleasure… Coming myself from a tiny kingdom, i know how difficult language somtimes can be…
Can anyone tell me how/what the widget is for? What info can it display?
It can display a specific groupchat
See example:
So I use my WhatsApp as a timeline to send useful info to. So I can see it in my WhatsApp and also on my wall :slight_smile:
Okay, thanks, however when i enter the reguested code from the widget, in the groupchat i want to add in the widget, nothing happens… How do i get it to work?
@Nastybaloo and homey is in that groupchat as a admin?
Not Homey… How di i do that? ( i am an admin in there)
@Nastybalood I really need more info on your setup before I can help you
Did you configure WhatsApp in homey? Or did you just install the app and tried the widget? Because the widget does need a WhatsApp device first
