Reconnecting with WhatsApp solved the problem.
However, this did not work at first, it resulted in a timeout.
Afterwards, the app itself indicated in the settings that the device had to be re-registered.
Do you know why WhatsApp does not receive anything in homey? If I create a flow to send a message it does so, but reading text from received messages does not work.
I would like to set it up if I receive a message from the emergency service with the word “emergency” in it from a certain number and then it will start a flow.
Thanks for your replies, after doing some electrical work in my house and switching the fuse so the homey was powered again, everything worked flaweless. Even the P2000 app that never worked, started to work.
Absolutely love the App - works great! The only issue that I have is that WhatsApp seems to disconnect from the Ubuntu device after a period of time. I only find out after realizing that I’m no longer getting messages. Is there a way to keep the connection ‘live’ longer. Again - great app, thanks!
I had the same problem with sending messages from OpenAI with Whatsapp. The Whatsapp app crashed and when trying to pair again i get a timout. Don’t know what to do to get Whatsapp stable again.
